Author Topic: Fireplace front  (Read 41088 times)
cumesoftware
Fireplace front
« on: April 02, 2008, 11:39:38 am »
This is a fireplace front that I'm planning to use in my palace room. It will be one of those antique, huge fireplaces, and a very elaborated one. The whole room is a work in progress, but it is only live on my mind, for now.
This is just the beginning of a decorated side stone. I will only make one. The other will be mirrored.
You can see the half column that will be on each side of the fireplace. Still much to do. Only 50% of the column is finished (about 5% of the whole work and about 0.1% of the whole room).
spicy
Re: Fireplace front
« Reply #1 on: April 02, 2008, 11:42:15 am »
It looks good. I like the spiral thing going on. Just waiting t osee the full fireplace, i think it will turn out good
Re: Fireplace front
« Reply #2 on: April 02, 2008, 02:57:22 pm »
i saw some of your other elements a while back, and i was already thinking that this is going to be an absolutely stunning scene when you've finished - this just confirms what i was thinking!  excellent work!
Re: Fireplace front
« Reply #3 on: April 02, 2008, 05:33:06 pm »
Very, very nice.
Your column looks similar to the legs of the table I have in my museum.
If you'd like to compare I can post an image.
cumesoftware
Re: Fireplace front
« Reply #4 on: April 02, 2008, 08:20:49 pm »
Thanks. The building process is quite similar, actually.
Very, very nice.
Thanks. I would like to take a look at that table, when possible.
« Last Edit: April 02, 2008, 08:22:48 pm by cumesoftware »
Re: Fireplace front
« Reply #5 on: April 03, 2008, 04:55:44 am »
Looks high poly, could you show a wireframe
I'm guessing you used the rope making technique
Re: Fireplace front
« Reply #6 on: April 03, 2008, 05:06:59 am »
Here's the table. The legs are made from different parts and the twisted section is a long cube.
cumesoftware
Re: Fireplace front
« Reply #7 on: April 03, 2008, 05:41:21 pm »
Today I've been busy and did not much. Nevertheless, the decorative column is 100% complete. The base is pretty much complete too. Here is the model:
Here is a detailed view of the wireframe:
Nice room! Thanks for sharing it with us.
I never use modifiers and warps for the twisting effects, due to lack of control. It is all made by hand.
It is not quite a high poly. It is a medium poly actually. You can see the wireframe in the last image above. Hope it is sufficiently detailed.
« Last Edit: April 03, 2008, 05:49:06 pm by cumesoftware »
Re: Fireplace front
« Reply #8 on: April 03, 2008, 06:04:32 pm »
...you used the lathe tool for that little round bit at the base, right?
anyways, your dedication to your modelling work is quite impressive, i'm sure i wouldn't have the patience to build something like that!
Re: Fireplace front
« Reply #9 on: April 04, 2008, 03:36:06 am »
Thank you for the additional pics. I can see it much clearer now and your column is totally different from my table legs.  ;D
Wonderful work !
cumesoftware
Re: Fireplace front
« Reply #10 on: April 04, 2008, 08:37:01 am »
Now the left and right pillars are 100% complete, and the respective columns have bases and capitals. The left and right pillars are separated meshes.
Below you can see the wireframe:
And the rendered image:
Wonderful work !
Thanks once more. I didn't used the lathe tool, due to my inability to convert a linear mesh to a path. I suggested that function to Steve, though. It was made using a copy/paste/rotate pattern.
« Last Edit: April 04, 2008, 08:41:42 am by cumesoftware »
Re: Fireplace front
« Reply #11 on: April 04, 2008, 05:07:49 pm »
You can't put a mesh on a path, but you can extrude a spline on a path.
But it does look like the lathed the base of the column (not the twisted part) around an axis.
cumesoftware
Re: Fireplace front
« Reply #12 on: April 05, 2008, 07:22:13 am »
I've made the base fire guards. They are pretty basic when compared to the posts (columns), but I think they only need to be decorated on the outside. Here are the pics:
The wireframe with faces:
The rendered model:
Still to do is the sill (should be easy), the lintel (heavily decorated) and the supporting brackets (heavily decorated too). The final model will have a total of 8 meshes.
Re: Fireplace front
« Reply #13 on: April 05, 2008, 07:36:19 am »
looks cool - just wondering though, what's the little block on the inside of the bottom corners do?
cumesoftware
Re: Fireplace front
« Reply #14 on: April 05, 2008, 08:50:13 am »
They are merely structural. I thought they would provide structural strength by distributing the downward force from the post to the sill. They also are a bit of decorative and provide a small protection from the fire.
