Author Topic: Sequence rotation.  (Read 5046 times)
Darknessspliter
Sequence rotation.
« on: October 25, 2014, 09:59:16 am »
Hello guys.I have a problem with the rotation directions in sequence.I have 2 same directions and one different for hand instead of 3 different .Can you tell me how to fix it,please?
« Last Edit: October 25, 2014, 10:00:40 am by Darknessspliter »
Re: Sequence rotation.
« Reply #1 on: October 25, 2014, 12:37:33 pm »
As far as I can tell, that's just how it ended up after rotating along the Z-axis. I'm guessing your figure has the arms straight out to the sides in a T-fashion, and in the sequence editor you rotated them down 90 degrees. You need to go back to your figure and rotate that upper arm bone 90 degrees on the Y-axis (right-click and drag). This way you'll get the range of motion you want in the sequence editor.
