Author Topic: question about float keys  (Read 12655 times)
Deepthought
« on: October 13, 2014, 09:40:26 pm »
the old anim8or spec describes a float key chunk as:
Code: [Select]
<floatkey> ::= floatkey { <$int> <$float> <$string> }
    <$int> is the frame number for this key.
    <$float> is the value.
    <$string> is a string used to modify the behavior of this knot.
    It is currently ignored.
in one of my files created with the new version of anim8or i see
Code: [Select]
floatkey { 0 23.025 6.9703 -6.9703 "S" }
the first number is still the frame number, and the second is still the value. any ideas what the next 2 are for?
Claude
Re: question about float keys
« Reply #1 on: October 13, 2014, 11:23:33 pm »
In this post Reply #22,you will find a zip file with a pdf file in it.It
should answer  your question.
http://www.anim8or.com/smf/index.php/topic,4739.msg35564.html#new
Claude
Deepthought
« Reply #2 on: October 14, 2014, 01:42:13 pm »
Thank you
