Author Topic: The Cut Tool  (Read 8545 times)
Blick Fang
The Cut Tool
« on: August 25, 2014, 12:07:03 pm »
Hey gang
I am trying to wrap my brain around the cut tool and I think I may have learned how to use it correctly, but want to confirm.  If I cut some faces, say for instance through a sphere.  It will make a new set of points and edges.  I simply "select all" the new points and edges and hit delete and there is my cut effect.  No matter where I put the cut line; through the middle of the face, a 1/3 down, 2/3 down, that will be the face(s) selected to be cut. In other words I can't cut the faces in half or any other increment
Hope this makes sense.  :-)
CrashDrive
Re: The Cut Tool
« Reply #1 on: August 25, 2014, 05:22:23 pm »
Hey Blick, the cut tool is used to arbitrarily cut through a face, adding a new edge and vertices.
You can then select any unwanted edges or faces and delete those as you normally would.
It's not meant to actually remove anything as a tool.
Blick Fang
Re: The Cut Tool
« Reply #2 on: August 26, 2014, 10:59:38 am »
Hi Crashdrive
I found a better way to explain what I want to accomplish.  I want to create a low poly person for rigged animation.  I haven't master that yet but found a model I'd like to rig with bones.  It was suggested that each part of the person should be seaprate; as oppsed to trying to rig a full model.
So I was going to use the cut tool to cut the arms the legs and the head accordingly.  I can't figure out how to do that. :)
CrashDrive
Re: The Cut Tool
« Reply #3 on: August 26, 2014, 01:39:25 pm »
Oh, Okay. Just select all the 'faces' of the part you want to separate and press Edit>Detach faces.
I hope this what you mean. :)
Blick Fang
Re: The Cut Tool
« Reply #4 on: August 26, 2014, 02:12:11 pm »
Hi Crashdrive
Thats not it. :-)
Say you have a sphere and you want to cut it in half and save each half as an object?
CrashDrive
Re: The Cut Tool
« Reply #5 on: August 26, 2014, 02:35:48 pm »
Hmmm. Maybe there is a script or different method but, I would do it as I explained.
You have to fill in the open ends after detaching.
Blick Fang
Re: The Cut Tool
« Reply #6 on: August 26, 2014, 02:59:06 pm »
Ahhhhhh this helps a lot.  Thanks!! :-)
CrashDrive
Re: The Cut Tool
« Reply #7 on: August 26, 2014, 03:42:28 pm »
Glad it helped. I forgot that you can also select the edges you want to cut and use the Edit > Loop Cut.
I almost always use the faces method because it's more visual and forget about that one.
Either way the results are the same. :)
