Author Topic: Anim8or runtime dependency problems  (Read 7405 times)
akulamartin
  • And I am, whatever you say I am
« on: May 23, 2014, 09:40:49 pm »
hello to all  :),my anim8or  didn't run so I ran a dependency check and here's the picture, could this be a problem on some systems
M
Re: Anim8or runtime dependency problems
« Reply #1 on: May 24, 2014, 11:29:14 am »
Without more information about your system, there's no way to tell for sure how relevant your findings may be to someone else.
So tell us, what's your setup?  PC type, operating system, etc.
« Last Edit: May 24, 2014, 11:31:36 am by RudySchneider »
akulamartin
« Reply #2 on: May 25, 2014, 11:37:38 am »
ok........I have a HP 635 with an AMD E350 running Window 7 ultimate 32 bit........that about it I hope  8)
M
« Reply #3 on: May 26, 2014, 08:06:43 pm »
Try running in compatibility mode for WinXP, and other compatibility options if that doesn't work.
akulamartin
« Reply #4 on: May 28, 2014, 01:59:19 pm »
Windows xp sp3 worked  :).....thanks.....I should have tried that....
M
« Reply #5 on: May 28, 2014, 05:04:05 pm »
No problem. This is definitely something that should be fixed though. It's easy to forget about it being a problem for new users.
