Author Topic: Environment map Y axis flipped for cube maps  (Read 14127 times)
« on: April 04, 2014, 12:37:09 am »
I think this is an old issue, but while working on the browser plugin I came across this problem and would like to see if this'll get fixed.
For cube maps, Up (+Y) is actually used as the Down (-Y), and vice versa.
Re: Environment map Y axis flipped for cube maps
« Reply #1 on: April 04, 2014, 02:33:53 am »
There are two different standards for cube maps with the Y axis flipped.  You can flip it with a check box  in the texture dialog.
« Reply #2 on: April 04, 2014, 02:57:14 am »
Hmm, I've only ever come across the other way in other applications. Well, I'll just flip them by default then.
MvGulik
  • [... Lost in Space ...]
« Reply #3 on: August 30, 2014, 07:21:29 pm »
Old one indeed.
Mmm, It seems to me you two are taking about different y-things.
