Pages: 1 [2]
Author Topic: creating/applying negative space?  (Read 22183 times)
CrashDrive
Re: creating/applying negative space?
« Reply #15 on: March 21, 2014, 02:32:52 pm »
JSmith_DumDumDumDumDum , hope it turned out okay for you.
captaindrewi, haha, I don't think you tried hard enough. I've seen your great work.
Here's my file .... a few 5 sided polygons are not a problem on this type of model, but are neatly disposed of if necessary.
« Last Edit: March 21, 2014, 02:49:00 pm by CrashDrive »
« Reply #16 on: March 21, 2014, 04:14:32 pm »
Thanks for the look of your file CrashDrive.I thought I would have to subdivide the meshes I created to achieve the smooth rendered look but realise now there is no need...errm i could have remained befuddled for quite sometime without your help.  :-[
what next?the knight :-\
« Last Edit: March 21, 2014, 04:20:48 pm by captaindrewi »
« Reply #17 on: March 21, 2014, 10:38:10 pm »
I wish I only knew what was causing the "concave" problem on my end. It seems that the example that CapatainDrew posted has a slightly concave slant where he placed the slit.
I guess something's we'll just never know. (right away)  ;D
CrashDrive
« Reply #18 on: March 22, 2014, 12:22:17 am »
captaindrewi, ya it would be a tough one subdividing that without a few wrinkles.
JSmith_DumDumDumDumDum,  You're still having issues I see. It seems like everything has a concave error.
What example are you referring that has a "slightly concave slant"?
« Reply #19 on: March 22, 2014, 01:17:14 am »
The bishops in CaptainDrew's exhibit. haha  ;D
But, actually, I simply took your Kniving suggestion, and it was sufficient in doing the job: I drew the cutmarks, highlighted all  the squares within in and then applied negative extrusion to those squares to create an inward dent. It was a bit funky, but interesting and creative-looking. I'm simply merely curious as to what this concave problem. was. It was just the bishop head. A lot of other things were able to boolean-combine.
« Last Edit: March 22, 2014, 11:37:00 am by JSmith_DumDumDumDumDum »
« Reply #20 on: March 24, 2014, 10:17:02 pm »
All Pieces completed
CrashDrive
« Reply #21 on: April 01, 2014, 03:07:09 am »
The chess pieces look great. Next time if you have a problem like the concave error thing,
you can always post your file and someone will probably find the answer.
« Reply #22 on: April 17, 2014, 02:19:21 am »
Didn't know this thread was still receiving replies. haha Thanks, CrashDrive. I will keep that in mind.
Of course, now that my issue with negative space is done, there's now a new issue with material appearance. Time for a new thread!  :)
Pages: 1 [2]
