Author Topic: ASL layer functions  (Read 15799 times)
ASL layer functions
« on: March 05, 2014, 06:04:05 pm »
There is a new int member layer in shapes that you can read and set.  It is silently clamped to between 0 and 7 if you assign a value out of range:
    int shape.layer;
Objects have new functions for accessing and setting layer properties:
    int object.IsLayerVisible(int layerNo);
    int object.IsLayerLocked(int layerNo);
    int object.ShowLayer(int layerNo, int ShowValue);
    int object.LockLayer(int layerNo, int Lockvalue);
LockLayer and ShowLayer lock and make visible the given layer when the second parameter is non-zero, respectively. They return the old value.
