Pages: 1 [2]
Author Topic: Changing the UV map without rigging the mesh again?  (Read 23980 times)
CrashDrive
Re: Changing the UV map without rigging the mesh again?
« Reply #15 on: January 30, 2014, 05:27:51 pm »
If you use 'Weights' instead of 'Bone Influences' you might want to try this.
After you have imported and replaced your object, go to figure mode.
Select the 'Multi-bone skin' button, double click your object and set to 'Bone Influences'.
When the envelopes show up, double click again and set to weights.
I rarely use 'Weights' in Anim8or but I did find a problem after importing with them.
If this doesn't help...a little trial and error works wonders.
JunkerKun
« Reply #16 on: January 30, 2014, 06:54:07 pm »
Sorry, I forgot to ask also, did you rename the new mesh to exactly whatever the old mesh was named as?
Uh... no? :V
I'll try it, but weights are more comfortable for me. I don't feel like setting influences, it's easier for me to just paint weights.
Pages: 1 [2]
