Pages: 1 ... 8 9 [10] 11 12 ... 20
Author Topic: Feature Request Thread  (Read 462455 times)
ClassicTyler
Re: Feature Request Thread
« Reply #135 on: May 07, 2014, 10:45:08 pm »
But when I do that, it doesn't show any light! We'll take this to another thread so we don't clog this one up.
« Reply #136 on: May 08, 2014, 03:41:11 am »
object ..emissive material, white, set to 1
add object to scene then add a light/lamp  at the object location.
you need both and are different things.
attempted to do something similar a while ago.
not quite succeeded :)
« Last Edit: May 08, 2014, 03:47:02 am by captaindrewi »
lppena
  • Anim8or, does a body good.
« Reply #137 on: May 08, 2014, 10:16:52 am »
I would think that some things have to be rendered to see things like lighting. I use Caligari Truespace and to actually see some efects like shadows won't appear until they're actually rendered to screen or file.
lppena
« Reply #138 on: May 08, 2014, 10:31:45 am »
I'm pretty sure this has been requested before, but it would be nice to have animation support added for a third party model export format of curret usage such as 3DS or some other common interchange format. This is the primary reason why I don't use Anim8or for many modeling projects. I've studied the layout of the native Anim8or model format and can't help wonder why the animation information can't somehow be translated in to a binary or text based format. Will this issue ever be doable? Thanks, Leroy.
ClassicTyler
« Reply #139 on: May 08, 2014, 01:23:43 pm »
Yes yes, I know it needs to be rendered! lol
I'll make a thread in the help section.
ClassicTyler
« Reply #140 on: May 08, 2014, 02:13:08 pm »
Well I think I got it figured out! :D
It just took a little placing and I finally got the idea to add the texture I wanted to the object. DUH TYLER.
The waves are supposed to be transparent, but the shadowing is so harsh it makes it look like a bottomless pit when rendered. But if I recall there's a script to make transparent items render shadows much lighter than regular objects? I'll look around.
Modeler_in_the_Myst
« Reply #141 on: May 16, 2014, 06:30:41 pm »
Fairly minor, but I'd like to be able to change colours of lines and such in the GUI. The contrast between the rotate screen tool (as opposed to object rotation) is such on my screen that half the time I forget it's even on until I try to affect something on screen. Another case where this would be useful is when the reference image has poor contrast with the line colours.
ClassicTyler
« Reply #142 on: June 03, 2014, 02:43:59 pm »
Along with my other requests, I have to ask...
Has there been a request for a water simulator? Something in the program that can make detailed looking water effects?
dancingshoes
« Reply #143 on: June 22, 2014, 05:51:15 am »
Late to the party...
+1 for transparent PNG support. Or better yet AVI (per frame) textures with transparency support.
Thanks.
« Reply #144 on: June 22, 2014, 03:57:53 pm »
You're never too late :-) Thanks for the suggestion.
« Reply #145 on: July 13, 2014, 08:22:17 pm »
Steve, I have no feature request at the moment (except maybe, as ridiculous as it'll sound, a Mac release far down the road if at all possible), but I've got to say your dedication to this software and the community around which it revolves is fabulous. Keep it up!
henrib736
« Reply #146 on: July 19, 2014, 09:57:33 am »
+1 Rendering Speed.
« Reply #147 on: July 19, 2014, 07:11:18 pm »
+1 Rendering Speed.
Right now, YOU actually have more control over that than Steve, since it's solely dependent on CPU speed.  There are some renderers, however, that can harness the blazing speed of graphics processors, but Anim8or ain't one of 'em, I'm afraid.
MvGulik
  • [... Lost in Space ...]
« Reply #148 on: September 20, 2014, 03:19:06 am »
If possible, a bit more basic texture handling options.
Figure it would, for example, make it more easy to get around a general 'Texture Repeat' side/edge effect.
« Last Edit: September 20, 2014, 03:20:46 am by MvGulik »
ClassicTyler
« Reply #149 on: September 22, 2014, 08:01:55 pm »
I don't know if this has already been mentioned, but is it possible to look into compatibility with transparent images? Say for vegetation and such.
