Author Topic: insert image/picture to anim8or  (Read 11161 times)
skyfall123
« on: March 04, 2013, 10:08:56 pm »
May i know how to insert image/picture to anim8or, so that when I render my movie, the image will appear there also?
I try import in the scene mode, but i cannot see the image?
Anyone can show me the actual way/steps?
TQ.
CrashDrive
Re: insert image/picture to anim8or
« Reply #1 on: March 05, 2013, 12:15:24 am »
In Scene Mode, look under Settings > Environment.
In the Environment Panel select 'image' and load your image 'File'.
It will be visible in the Camera View only.
You could also load your image as a texture and apply it on a plane in 'Object mode'.
Then import it as an object in 'Scene Mode'.
Hope this helps.
skyfall123
« Reply #2 on: March 05, 2013, 02:17:25 am »
Hi,
May I know how to  "load your image as a texture and apply it on a plane " ?
thanks.
skyfall123
« Reply #3 on: March 05, 2013, 02:23:58 am »
in Object mode, I choose Build> Preference image, then I load my image. Then I proceed to the scene mode, Build> Add object. Then I choose the image that I have load just now. Here, I found that the image is invisible, just a rectangular box appear on the plane.
Anyone an help?
CrashDrive
« Reply #4 on: March 05, 2013, 03:30:28 am »
Hmmmm...
I explained how to use a background image in a scene.
Did you not try that ?
The 'Reference image' is only used in 'Object mode' as a guide for modeling.
I think you might want to try reading the Manual first, before you go any further.
skyfall123
« Reply #5 on: March 05, 2013, 03:34:10 am »
ya, i have try to add background image in a scene.. thanks a lot.. its working.
