Author Topic: Can the orientation of a parmetric script be changed?  (Read 4786 times)
lppena
  • Anim8or, does a body good.
« on: February 13, 2013, 09:24:51 am »
I've noticed that some objects are created vertically by default in some parametric ASL scripts. Is there a simple script modification I can make to an existing script that creates the object horizontally by default, or is this only possible using the rotation button to manually rotate an object from vertical to horizontal after an object is placed in the work space? Thanks, Leroy.
