Author Topic: negative texcoords  (Read 9822 times)
Deepthought
negative texcoords
« on: February 05, 2013, 11:06:55 am »
Just so you know, for some odd reason, anim8or was outputting negative texcoord indices, causing a file read error next time i loaded the file.
Re: negative texcoords
« Reply #1 on: February 05, 2013, 11:46:44 am »
Can you provide more information, such as how to replicate it, or supply the file that is causing the error?
Deepthought
« Reply #2 on: February 05, 2013, 11:50:44 am »
no idea how to replicate, but here's the file
« Reply #3 on: February 05, 2013, 02:38:57 pm »
might be a classic case for using the autosave feature in future, then any work done will always be available from the last session.
Deepthought
« Reply #4 on: February 05, 2013, 05:35:20 pm »
i'll have to set it to do that.
I was able to go into wordpad and remove the offending indices, so at least i didn't lose my model.
