Author Topic: merge points and UVs  (Read 5410 times)
Deepthought
« on: January 23, 2013, 02:22:32 pm »
what does anim8or do with uvs if i merge points? does it interpolate, or will i have to re-map?
Re: merge points and UVs
« Reply #1 on: January 23, 2013, 05:07:43 pm »
Try it out for yourself and you'll find out. There's a save and undo feature for a reason ;)
(but to answer your question: UVs are preserved within reason. If you merge points so that it changes the number of edges for a polygon, or merge several points of varying distances together into one point, then things will start getting messy.)
