Author Topic: how to import multimedia element to Anim8or project?  (Read 7494 times)
supertk
« on: January 22, 2013, 03:36:55 am »
Hi all,
May I know does Anim8or support audio or not?
How do I import audio/graphic/ text elemets to Anim8or project?
many thanks..
Re: how to import multimedia element to Anim8or project?
« Reply #1 on: January 22, 2013, 03:45:20 am »
No, there is no audio support in Anim8or.
However, there are a number of ways to  add it, you can use movie maker that comes with your PC just load in the AVI and then add your audio,  if you want to add further audio once it is a WMV file ,then that can cause some problems.
So I would suggest you get VirtualDub http://virtualdub.sourceforge.net/  this is a free download.
The latest version will allow audio streams to be added, you can also append avis ( so long as they have been processed with the same resolution, frame speed and compression) and create an AVI from single frame renders, this is particularly useful if you are using the old version of anim8or (0.95) which can unexpectedly crash, and does not have the later autosave feature.
For titles and other graphics just make an Avi then append to the main anim8or project
ie Title avi - Main Anim8or avi`s - Credits Avi  But make sure that they are all the same Res, frame rate and compression.
« Last Edit: January 23, 2013, 02:52:11 am by kreator »
supertk
« Reply #2 on: January 22, 2013, 09:31:45 pm »
I see.. how about text? can we create text using Anim8or?
If cannot, can we import text element to it?
thanks.
supertk
« Reply #4 on: January 23, 2013, 01:17:17 am »
OK. How about adding other graphic/image? Does Anim8or support that?
« Reply #5 on: January 23, 2013, 02:46:56 am »
Anim8or supports 24bit jpeg and bmp files.... I suggest you read the manual, the link Raxx gave you http://anim8or.com/manual/
supertk
« Reply #6 on: January 25, 2013, 03:08:42 am »
ok. thanks so much...
