Author Topic: Modifier Woes  (Read 6087 times)
Blick Fang
Modifier Woes
« on: December 12, 2012, 02:44:01 pm »
Hi All
Why is it that when I save my project with a modifier, in this case a bend, I can't open it correctly?   The modifier is off to one side and the thing to be modified is there unmodified?
Re: Modifier Woes
« Reply #1 on: December 12, 2012, 05:47:42 pm »
modifiers tutorial, are you using effect modifier once you have bent/sheared tapered it?
Blick Fang
Re: Modifier Woes
« Reply #2 on: December 13, 2012, 09:47:14 am »
Hi Kreator
....hmmm.  I made a mesh.  Made made the modifier.  Told it to be a "bend"   Bound the mesh and modifier.  Double clicked the modifier.  Told it to bend 195 degrees.  Lovely.  Saved.  Opened later.  Not so lovely anymore.   Did  I miss a step?  I will check out the vid later at home.
Re: Modifier Woes
« Reply #3 on: December 13, 2012, 10:36:25 am »
yep you missed a step. You need to use  use "Effect Modifier" so it will not save.
Blick Fang
Re: Modifier Woes
« Reply #4 on: December 13, 2012, 10:50:52 am »
I saw that before and wondered about it. :-)
Just tested and that was the step I missed.
A lot of other bizarre things were happening too.
Back on track!   Thanks Kreator!!!
Blick Fang
Re: Modifier Woes
« Reply #5 on: December 13, 2012, 11:22:47 am »
on another note: Kreator, can you PM me my credentials to your website?   Thanks!
