Author Topic: Help! Windows 7 with Anim8or  (Read 7508 times)
Rockydude411
« on: November 09, 2012, 04:07:15 pm »
I downloaded anim8or on my Windows 7 64, bit computer, it is a Toshiba, if the matters, and once I pressed run, there was a while of nothing, then it said: "Anim8or has stopped working Windows can check for a solution to the problem. 'Check online for a Solution and close the program' 'Close the program.'" So I closed it. I did it again a few times and it said the same thing. So I decided to re-download it, so I was gonna delete the first one, when I searched it, it wasn't there, so I re-downloaded it, and it said the same thing, so I checked "View Problem details", and it said this : "Problem Event Name:   APPCRASH
  Application Name:   Anim8or.exe
  Application Version:   0.9.5.0
  Application Timestamp:   45c94bfc
  Fault Module Name:   Anim8or.exe
  Fault Module Version:   0.9.5.0
  Fault Module Timestamp:   45c94bfc
  Exception Code:   c0000005
  Exception Offset:   000aa23c
  OS Version:   6.1.7600.2.0.0.768.3
  Locale ID:   1033
  Additional Information 1:   0e12
  Additional Information 2:   0e12625621327df2b2bc4085eecc5dc0
  Additional Information 3:   8480
  Additional Information 4:   8480603ade7f290c6c75b446e768e543
Read our privacy statement online:
  http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0409
If the online privacy statement is not available, please read our privacy statement offline:
  C:\windows\system32\en-US\erofflps.txt" So I searched on the internet, and nothing. But it did leave me to a forom, so I did what it said, but it didn't work. So I am asking here.
Re: Help! Windows 7 with Anim8or
« Reply #1 on: November 09, 2012, 04:40:14 pm »
Download and use the .97 Preview instead. Right-click the Anim8or.exe file after extracting it from the zip file (don't execute it from within the zip file), go to properties, then go to the compatibility tab. Try setting compatibility for windows xp, and disable visual themes and desktop composition.
Rockydude411
« Reply #2 on: November 09, 2012, 04:51:34 pm »
Thank you, but, I saw that in a video, but, I don't see a compatibility tab on it.
Rockydude411
« Reply #3 on: November 09, 2012, 04:54:54 pm »
Wait, never mind, thank you. (i was downloading the wrong one) Thank you so much!
« Reply #4 on: November 10, 2012, 02:54:55 am »
I think this is already on da forums.....try searching it. Welcome, btw. Glad to have a real person and not a spammer.
Check this link out ... as cello said its worth checking posts with the search tool , http://www.anim8or.com/smf/index.php?topic=4205.0
As for spammers the site needs updating to at Least SMF V2.0 , then the problem might go away, with the security mods it offers.
