Author Topic: Help!  (Read 11911 times)
Alchemystic
Help!
« on: March 26, 2008, 05:59:47 pm »
Is it possible to make haze in Anim8or? Not fog, but a haze in one area. Also, can you make flares, like around a star or something? I tried making a texture like that, but it turned out looking like a huge animated ion. that didn't quite work. Any help would be appreciated. Thanks in advance. :)
« Last Edit: March 26, 2008, 06:02:01 pm by Alchemystic »
Re: Help!
« Reply #1 on: March 26, 2008, 06:59:02 pm »
Can you give drawing or examples of it?  I'm not exactly sure the type of haziness you're trying to achieve.  I also don't really understand what kind of thing you're trying to do with a flare, though for that kind of a thing I'd highly encourage trans maps.
Re: Help!
« Reply #2 on: March 27, 2008, 05:49:25 am »
Do you mean haze like this:
http://anim8ormovie.14.forumer.com/viewtopic.php?t=659
You might have to ask Starbuck
Alchemystic
Re: Help!
« Reply #3 on: March 27, 2008, 08:44:11 am »
Yeah, thats what I'm trying to make for the haze. I found a tutorial for haze like that once, but i was still working on the tutorial robin animation, so i didn't really care about it then. Now when I need it, I cant find the tutorial.
I'm trying to make a solar flare, like this: I took that picture from celestia. What I mean is like a visible light. I tried a trans map, but it turned out too solid looking.
Thanos
Re: Help!
« Reply #4 on: March 27, 2008, 09:11:37 am »
I haven't tried it, but you could make a transparent sphere around your object, and give its material that "glossyreflector" class that the new ART raytracer supports. Check this: http://www.anim8or.com/download/preview/art_raytracer.html
Re: Help!
« Reply #5 on: March 27, 2008, 07:57:42 pm »
Could you post the transmap you used?  It looks like you'll definitely want to use a transmap, but I'm not sure why it's coming out solid.
Alchemystic
Re: Help!
« Reply #6 on: March 28, 2008, 12:02:13 pm »
I'll try that, thanks.
I used a water texture just for an experiment, i didn't seriously try using a transmap. This is the texture though. I wanted to make it look like there were sunspots, and that part worked, but it looked to solid.
Re: Help!
« Reply #7 on: March 30, 2008, 04:09:38 am »
In a transmap, black colors are completely transparent and white is completely opaque.  So, since I'm guessing there aren't many true blacks in that image, it would look too solid and not very transparent.  I'd advise trying to create your own transmap.
