Author Topic: Noob: frame rates?  (Read 7929 times)
Jeff2207
Noob: frame rates?
« on: March 26, 2008, 10:11:25 am »
Thank you for a wonderful program, I wanted to try my hand at modelling and looked at several programs but Anim8or is certainly my favourite.  I've made a few simple models so now want to try some animation.  I'm a bit unclear about frame rates, is it just a question of higher is better quality/slower render or are there other things to take into account?  I think I remember reading somewhere that film animation is 24 fps, is that the best to use?  Any help would be appreciated.  :)
Re: Noob: frame rates?
« Reply #1 on: March 26, 2008, 10:20:20 am »
24 fps is standard and is best to use.
Jeff2207
« Reply #2 on: March 26, 2008, 12:05:04 pm »
Thanks for the quick reply.  That's what I'll use then.
mcheccyb
« Reply #3 on: March 26, 2008, 12:05:49 pm »
24 as frame rate basically means there is 24 frames per second (or fps) the more frames per second the smoother the animation is.
24 is the standard for films.
i believe some films (wallace and gromit for example) go a bit mad and decide to use a very high frames rate.
wallace and gromit used 60 frames a second.
the higher the frame rate, the longer a movie takes to render.
hope this helped.
