Author Topic: Light Test  (Read 11867 times)
ncl32
Light Test
« on: March 25, 2008, 08:29:45 pm »
Hey guys nate here. As I have seen that the new Anim8or has come out and my dreams have come true to an extent I have came up with a small lighting render. Although no matter how many times I refer to it as small it took my pile of junk nearly 3 hours to render.  ;) Any way heres the render. Any way as you can see its a nifty looking render test. Now do note that I rendered it with only 4 samples and the Regular Sampling Method. My computer probably would have taken a week to render it with the 25 sample rate that you can plug in there... 8) Any way the point of this render and light test is to see if the Ray tracing engine "ART" can render a massive light distribution in a small scene. To do this massive light distribution I assumed the idea like it would occur in real life. If possible, that is as well. So as you can see there is a transparent sphere in the center of the room. This was planed to distribute the light around the room and to have the surrounding objects still recieve the light as well. So I crammed a local light inside of my clear ball with a Kr of 1.33 (glass) Trans of .1 and Rough of 10000. Then I stuffed it all into a huge elongated box, flipped normals and added a few pretty balls for good measure...
Ok, well lets see what happened. As you can see the upper half of the image looks to as if it might have worked. But the lower half it dark? Hmmm, pondered me after getting home from work after the 3 hour render... Lets take a deeper look. Another thing you might also realize is that the room that all of our friendly objects are in is a bit reflective. I did this because everything in the world has a small amound of reflective value. And yes I know that that is a bit much... Just a test do note... Any way everything seemed to go to plan and then I also notice the deformed shadowing on the upper half. Mainly right near the Dielectric sphere. Any way maybe this can be some help to you Steve. I dont really know how. Or Im just a bit worn out  from work today. If any one wants any more info just comment.
Thanks,
Nate
ncl32
Re: Light Test
« Reply #1 on: March 25, 2008, 08:30:22 pm »
The Camera View
ncl32
Re: Light Test
« Reply #2 on: March 25, 2008, 08:31:06 pm »
And a wire from Left View... Post away!
Re: Light Test
« Reply #3 on: March 26, 2008, 04:17:57 am »
does anim8or support radiosity?
maybe that's why the bottom is dark
Re: Light Test
« Reply #4 on: March 26, 2008, 06:00:30 am »
You said you placed the light inside one of the spheres; The problem is that all the spheres cast shadows (ART renderer doesn't obey shadow settings... see http://www.anim8or.com/smf/index.php?topic=388.0) - also the sphere that has the light inside casts shadows... I think in the end the light coming out of the sphere will be messed up and the shadows won't work correctly in this scene...
Quote from: Tanzim
No, it doesn't... yet
ncl32
Re: Light Test
« Reply #5 on: March 26, 2008, 10:12:20 pm »
yeah i know, its just a small test. And i know it doesn't support radiosity. I just wanted to see if by small chance it would calculate it and render the image to at least seem correct. lol. But heck i got a cool looking render! And as for radiosity, one day. But people have yet the time to crank out some awesome looking Anim8or work yet so im content for now with ART. And now all i need is a better computer now since Anim8or can produce amazing looking renders! Hey so who will be the first on www.3dtotal.com with a 100% Anim8or render? Now thats a challenge!
Nate
