Author Topic: Muvizu and Anim8or  (Read 9233 times)
Muvizu and Anim8or
« on: July 19, 2012, 03:06:46 am »
Just a heads up on Muvizu, which seems to be a good character animation system for new users, in built movement, lip synch to a degree,
I am currently adapting my anim8or models for use in this program
http://www.muvizu.com/
« Last Edit: September 06, 2012, 03:33:58 am by kreator »
Re: Muvizu and Anim8or
« Reply #1 on: July 19, 2012, 05:43:37 am »
fun prog...great for animatics  and such.
« Reply #2 on: July 22, 2012, 03:06:03 pm »
Ive heard of this software, it didn't look all that great to me.
ianross
« Reply #3 on: August 16, 2012, 07:40:06 am »
Hi Kreator, what program are you using to convert I assume 3ds from anim8or to ase muvizu, also once you get your model into muvizu can you U.V map textures, alpha maps and bumps?
« Reply #4 on: August 30, 2012, 08:37:03 am »
Ian, using GILE{s} (use square braces for the software title!) much easier to add to muvizu. Better to use UV map for the whole model, you can also use AO  no transmaps or transparency although you can use animated textures.
link: http://www.frecle.net/index.php?show=giles.download
Here`s a nice short animation from Dreeko
Hope you all like it
« Last Edit: September 06, 2012, 03:35:29 am by kreator »
