Author Topic: Are there any other syntax checkers that work with ASL scripts?  (Read 14061 times)
lppena
  • Anim8or, does a body good.
I run Windows ME but the ASL editor won't run the program. Any suggestions for alternatives to checking the syntax used by Anim8or? Thanks. Leroy.
Re: Are there any other syntax checkers that work with ASL scripts?
« Reply #1 on: March 17, 2012, 10:22:48 am »
Sorry but ASL editor is the only one out there. Are you sure you have everything installed for you to use it on Windows ME?
It runs on the .NET framework, so install these two:
http://www.microsoft.com/download/en/details.aspx?displaylang=en&id=21990
http://www.microsoft.com/download/en/details.aspx?displaylang=en&id=65
Restart if necessary, and try running the ASL Editor again.
Otherwise you'll have to use a general text editor and use Anim8or's Debug Output window for error messages.
lppena
« Reply #2 on: March 17, 2012, 11:24:58 am »
Thanks for the web links Raxx I'll check in to it when I get to work. Hopefully, that'll do the trick for WIN ME. Leroy.
