Author Topic: Anyone know where to get a copy of ASL Editor vrsion 2?  (Read 14019 times)
lppena
  • Anim8or, does a body good.
« on: March 16, 2012, 06:52:24 am »
I have version 3.5 but it won't run under Windows ME. Will version 2 run under ME? Thanks Leroy.
Re: Anyone know where to get a copy of ASL Editor vrsion 2?
« Reply #1 on: March 16, 2012, 09:57:41 am »
I don1t know if it runs under ME but here are 1.0 1.3 and 2.0 versions.
I think a windows upgrade might be wise?
Readme from Version 1.0
|||  ASL Editor - an Anim8or Scripting Language development tool  |||
Features:
- Syntax highliting with customizable font settings
- Syntax specification is saved in an external XML file
- Undo/Redo functions
- Recently opened files list
- Easy localization to any language
System requirements:
- Windows XP/Vista or newer (it might work on earlier versions too but I didn't have a chance to try it...)
- Microsoft .NET framework 3.5 or higher
Important notes:
ASL Editor is in a very early stage of its development and although it is pretty stable, it's still a beta version!
Save your work often!
Do NOT rename, remove or edit the Settings directory or the library.xml file! The purpose of library.xml is to store
a simple ASL language specification (such as list of keywords etc.). Therefore library.xml may need to be updated
every time a new version of Anim8or is released, but it's recommended not to edit the file yourself. If you have a good
reason to edit library.xml, make a back-up copy first because ASL Editor won't launch if the file is damaged.
The ASL Editor user interface can be easily translated to any language. Currently available languages are English (default)
and Czech (I'm unable to provide more translations :/). If you want to create a new translation, create a new .lng file (see
Sample.lng for further instructions) and send it to me afterwards if you want it to be included in the next main release.
« Last Edit: March 16, 2012, 10:03:01 am by kreator »
lppena
« Reply #2 on: March 16, 2012, 03:38:19 pm »
Thanks Kreator. I have Windows ME on an old Laptop at work. I eventual plan to replace it as funds become available to upgrade to a newer system, but for now it keeps me occupied and Anim8or runs okay under ME. It's just the newer written software that won't run on such an old OS. Thanks again. Leroy.
