Author Topic: Why are some objects uneditable?  (Read 7733 times)
lppena
  • Anim8or, does a body good.
« on: March 13, 2012, 06:18:31 am »
I noticed this with object created script object. Do they differ from the default objects included with Anim8or. Is there a way to convert the uneditable objects in to an editable mesh? Thanks.
Opps, my bad apparently some if not all can be converted after selecting them and selecting the convert to mesh option.
« Last Edit: March 13, 2012, 08:16:56 am by lppena »
Re: Why are some objects uneditable?
« Reply #1 on: March 13, 2012, 06:22:30 am »
Select the object, then click on Build>Convert to Mesh.  This will convert the script or primitive object to an editable mesh.
lppena
« Reply #2 on: March 14, 2012, 12:52:56 pm »
Thanks ENSONIQ5, I finally figured it out. Now I can use the parametric scripts and modify the resulting object in the editor itself. PS: I may add a new forum on my modeling forum for using Anim8or to create models for Battlezone II Combat Commander; it's basically a moddable video game that people can create 3D models and props for the game. It uses an obsolete XSI model format, but I'm in the process of modifying an X exporter script to output text data that the game can read and load as a game model. Leroy.
