Author Topic: bones don't work  (Read 9500 times)
Deepthought
bones don't work
« on: December 04, 2011, 03:58:22 pm »
I've created a figure, and i'm trying to animate it. I've set which axis i want to be free, but in the sequence editor, i can't make a bone rotate. why is that?
Re: bones don't work
« Reply #1 on: December 04, 2011, 07:07:35 pm »
You most likely haven't chosen to use weights or bone influences. You'll have to skin the model first, I'm sure someone will come in and follow up on that. Welcome to the forums, by the way!
Deepthought
« Reply #2 on: December 04, 2011, 08:29:55 pm »
what? i've done it once before without doing that and it worked. maybe is that a new requirement?
Deepthought
« Reply #3 on: December 04, 2011, 08:34:08 pm »
i tried it just in case, but on windows 7 it crashes if i do.
« Reply #4 on: December 04, 2011, 09:03:36 pm »
Did you make sure to set the X-axis to no limits or a defined limit (if you did it properly then a partial green circle appears around bone, representing the X-axis). Also, if you're setting bone limits in the sequence editor then you have to switch out and back in for those limits to update.
 If you set the bone limits properly, then perhaps it's because of the field of view or mouse button you're trying to use. Try switching views or arc rotating, and trying different mouse buttons. Usually it's the left mouse button for the X-axis, but generally it depends on what view you're using.
Deepthought
« Reply #5 on: December 05, 2011, 10:40:08 am »
ok i set no limits, but don't see a green circle.
« Reply #6 on: December 05, 2011, 01:13:17 pm »
To make the bone axes visible, make sure this button is pressed:
Some useful links for beginners to the figure editor:
Manual: http://anim8or.com/manual/5_figure_editor.html
Simple Walk Tutorial
Skinning Tutorial (does not include weight painting)
Looks like some of the old tutorial sites have gone down...
« Reply #7 on: December 05, 2011, 03:05:21 pm »
Good idea to point him that way, Raxx. One thin i want to say, DT, is that you wanna choose bone infs vs. Weights dependent upon what kind of model you're skinning, in which case weights are generally used for organic models, from what I've gathered on the forums (although i will admit that I've heard many cases in which user prefer to use only one type for all)
Deepthought
« Reply #8 on: December 05, 2011, 05:29:18 pm »
huh. that's strange. int the tutorial it says to hide objects, and i did that and it works. that's stupid.
« Reply #9 on: December 05, 2011, 05:54:19 pm »
It works whether they are hidden or not. Have you been selecting the bones first before you tried rotating them with the bone rotate tool?
Deepthought
« Reply #10 on: December 05, 2011, 06:44:46 pm »
it was the left button in the figure but the center one in the sequence editor. on win7. but it was the left in xp.  ::) sigh
