Author Topic: Diamond Trial  (Read 9241 times)
G3
Diamond Trial
« on: November 08, 2011, 08:37:47 am »
It is first time me using Art raytrace renderer..
I think it is still possible making out some germstone in anim8or
still shadow isn't including the lightrays  which should be beside the shades under diamond( guess it should be done manually)
G3
Re: Diamond Trial
« Reply #1 on: November 08, 2011, 09:22:25 am »
Several progresses that i made
« Last Edit: November 08, 2011, 09:23:57 am by G3 »
Re: Diamond Trial
« Reply #2 on: November 08, 2011, 11:11:44 am »
Looks nice! And yeah properties of light through solids hasn't been implemented yet in ART.
dwsel
    • Dwsel art
Re: Diamond Trial
« Reply #3 on: November 08, 2011, 02:35:30 pm »
I like the result on the second image! A bit of reflective environment really makes wonders here.
The first one is definitely missing more things to be reflected around it, dispersion and caustics. You can easily fake dispersion by rendering 3 versions - each with different IOR and composite RGB channels just like here http://www.mentis.ca/design/graphics/dispersion/ For caustics you can place light behind the object, close to the floor.
dwsel
    • Dwsel art
Re: Diamond Trial
« Reply #4 on: November 09, 2011, 06:49:07 pm »
I really don't know what I was thinking about when writing this. Fakeing refractive caustics behind your diamond gem is really bad idea, because when light goes through pavilion instead of crown that only means obviously bad design 8) Caustics behind fit objects like lenses and spheres...
Here's my try at rendering gems. Design modelled roughly after reference: http://www.faceters.com/designs/ad6/check11.shtml - quite simple and quick cut that I even wanted to make if I only had gear to perform it.
« Last Edit: November 09, 2011, 06:51:55 pm by dwsel »
G3
Re: Diamond Trial
« Reply #5 on: November 09, 2011, 08:52:43 pm »
Hey dwsel how did you put the color on it ?
is there any option that covers color?
dwsel
    • Dwsel art
Re: Diamond Trial
« Reply #6 on: November 10, 2011, 02:09:22 am »
It's 'dielectric's' feature. http://www.anim8or.com/download/preview/art_raytracer.html . You have to set diffuse colour and add 'UnitDistance' attribute to material set to low float value.
