Author Topic: Half Life or Counter Strike  (Read 7127 times)
LeBurdin
« on: March 21, 2008, 05:03:10 pm »
Hi,
im a n00b and i was wondering if you could use the models you make in anim8or for counter strike or half life, so if i make a model i could use it in the game.
thanks for the help ;D
Re: Half Life or Counter Strike
« Reply #1 on: March 22, 2008, 05:39:03 am »
what do you mean, like maps or characters, weapons etc
CydoniaKnight
« Reply #2 on: March 23, 2008, 01:17:01 am »
This is the second thread that you've made about this. Don't repeat posts please.
« Reply #3 on: March 23, 2008, 02:37:12 pm »
You could model in anim8or and probably get the models into CS somehow.  To do this you'd have to use an exporter someone else uses that could export to a correct format.  Or, you'd have to get a program that can export to the CS format, and export from anim8or, import to the other program then export again.  I believe someone wrote a C++ format that can export figures and perhaps animations recently, but there are hardly any of those (that work with animations).
So if I were you, search around the forum and google for anim8or exporters that export to a useable format.  A lot of it will be a learning experience though, remember that.  We don't have all the answers because we haven't tried before!  But I'm sure it's possible in some way.
Edit:
http://www.anim8or.com/smf/index.php?topic=382.0
Check out that thread, I'm sure that this could be very useful.  Still, I don't think it will be able to be done with anim8or alone, you'll need export programs to get the models into the games.
« Last Edit: March 23, 2008, 02:38:43 pm by hihosilver »
