Author Topic: Scaling up a texture  (Read 6395 times)
« on: June 04, 2011, 06:05:02 pm »
Hi, everyone. I'm designing a bag for my portable Roland DAW, and I made a decent trans map to go on the front of the plastic casing which would be on front. Only problem is, it doesn't fit the correct size, it's a bit too small. I've triede making the actual texture bigger, but that only adds more definition, no make it any larger on the model. what do I do?
benzjie
Re: Scaling up a texture
« Reply #1 on: June 04, 2011, 06:32:53 pm »
It's the same as the Arc rotate / zoom tool but instead of that you use the UV ( yellow) circle . Alt RMB if i remember correctly
« Reply #2 on: June 05, 2011, 09:10:21 am »
You're right! Thanks, benzjie!!
