Author Topic: Was doing hand model.  (Read 14730 times)
Daniel
« on: December 27, 2007, 09:31:49 pm »
I have just been doing the hand model. I have got up to the part where I can place in modifiers. I can clearly see that the pictures shown have obviously more than one modifier applied, yet I am unable to apply more than 1, as it says "Must select exactly 1 modifier and 1 object" when I try to bind the modifier to the object.
Can anyone help me?
Re: Was doing hand model.
« Reply #1 on: December 28, 2007, 04:24:38 am »
I am not sure exactly what model you are building, but modifiers can only be applied one at a time.  Say you want to bend an object, and also twist it.  First, construct the twist modifier, bind it, and "effect" it.  Then construct, bind, and effect the bend modifier.
« Reply #2 on: January 01, 2008, 03:27:53 pm »
You need to select both one component of your model and a modifier.  Then the Build->Modifiers->BindModifier command will work.
