Author Topic: Anim8or Meshes  (Read 8929 times)
jonny
Anim8or Meshes
« on: March 20, 2008, 06:32:02 pm »
I have been looking all over the internet for meshes of a minotaur. I have found several for other animation programs like 3D Max and lightwave 3D but nothing for anim8or. Does anyone know of any good meshes that I can download or any tutorials that I can follow.
I am a newbie to animating so need any help that I can get.
Thanks in advance for any replies
Re: Anim8or Meshes
« Reply #1 on: March 20, 2008, 07:39:31 pm »
Have you checked with the meshes that you found if any had a file extension compatible with Anim8or import ?
Dosser
Re: Anim8or Meshes
« Reply #2 on: March 20, 2008, 07:49:30 pm »
You simply won't find models in the an8 format.
Luckily, anim8or can import from the 2 most common formats: .3ds (3d studio) and .obj. Just go to object -> import and load the file like that.
Though perhaps it would be more intuitive if you could load / save for all formats in the same load / save command, rather than treating .an8 as a 'special case' with its own save command. I know I've also had trouble finding the command to import.
jonny
Re: Anim8or Meshes
« Reply #3 on: March 21, 2008, 07:24:36 am »
Thanks for the help. I will have a look to see if the meshes I found have a compatible file extension. If they do then I will import them like you say.
