Author Topic: Scripts in scene mode?  (Read 9244 times)
Janro
« on: November 27, 2010, 10:57:42 pm »
Would it be possible to make a script that operates in Scene editor?
Because I was wondering if it's possible to create a script for keyframing all the bones in Scene editor? I find at times that I don't want to animate in Sequence editor for sequences which I will not reuse or if there's an interaction with another object/figure. However I use the command key all bones a lot in the sequence editor. Would it be possible to have a command like this via script for the scene editor?
odp04y
Re: Scripts in scene mode?
« Reply #1 on: November 28, 2010, 07:39:11 am »
As far as I know scripts don't work in scene mode. However someone more experienced with ASL may have found a workaround.
