Author Topic: Box Modelling?  (Read 12992 times)
RossMcKay
Box Modelling?
« on: October 14, 2010, 06:21:48 am »
I have tried to box model using a tutorial on youtube and it was modeling a Desert Eagle but the tutorial wasnt complete as there was no part 3 so I dont know what to do when I finnish so here is the stage im at
I want to get the head into a 3D model but I dont know how to using the box model method.
And when I go on youtube on this video
When I click the bottom right tool I cant draw lines.
Thanks
Also if anyone could give me a tutorial on how to make a 3d head that would be great
The reference images came from got3d.com.
Re: Box Modelling?
« Reply #1 on: October 14, 2010, 10:03:27 am »
Hi RossMcKay :)
you start modeling wrong...dont use box/flat.
there many ways to modeling a head..
see this topic: http://www.anim8or.com/smf/index.php?topic=3542.msg25417#msg25417
or this: http://www.anim8or.com/smf/index.php?topic=1070.0
cheers  ;)
« Last Edit: October 14, 2010, 10:08:35 am by neirao »
RossMcKay
Re: Box Modelling?
« Reply #2 on: October 14, 2010, 10:57:12 am »
Thanks but on that 2nd link where it says
follow steps using and in Anim8or, is easy!
How do you use them 2 tools and when I'm selecting faces I have converted to mesh and I can only select the faces behind how do I fix it.
Thanks
Re: Box Modelling?
« Reply #3 on: October 14, 2010, 11:46:15 am »
look up edge loops. they will give u a great view on how to model.
i think you have your faces inside out. if they are blue when you select them that means the inside is on the outside. select all your faces and go to edit>flip normals. (i think its in edit).
also look at some (of the better) models wireframes. you will get a better idea on what to do with that as well.
Re: Box Modelling?
« Reply #4 on: October 14, 2010, 03:14:53 pm »
hi RossMcKay, :)
this 2 tools, for undestand how use, the way is read the Anim8or Manual
is easy please see in: http://www.anim8or.com/manual/4_object_editor.html
please try and response if you could ok? :)
sorry my english  ::)
Re: Box Modelling?
« Reply #5 on: October 14, 2010, 05:37:41 pm »
If you are going to box model a head then you use just one box and not three.
If you look at your third picture, how do you plan to join these boxes into a head ??
RossMcKay
Re: Box Modelling?
« Reply #6 on: October 15, 2010, 02:04:05 pm »
That was what I was wondering how to join the 3 together and you said 1 box how would i add the ears and eyes?
Thanks
Re: Box Modelling?
« Reply #7 on: October 15, 2010, 03:17:08 pm »
When you watch the youtube video, most new users are not aware that qqqsimmons has pre-set up his modelling so what you are actually looking at is a premade face that has the top edge selected.
So he started by using the extrude edge tool, dragging the edge up then switching to the move tool to adjust his points to the profile of the face.
Once he has the profile it is just a case of extruding the edges and adjusting to the other ref view he has ... ( I might add it looks easy but it is not!! )
part III is here...
« Last Edit: October 15, 2010, 03:54:06 pm by kreator »
