Pages: 1 [2] 3 4 ... 9
Author Topic: My new project  (Read 105641 times)
CoriDavis
  • SammyJ Studios
    • SammyJStudios.net
Re: My new project
« Reply #15 on: August 29, 2010, 07:23:58 pm »
Too fat? really? I thought it was too skinny so I made it a bit wider
blazecon0
Re: My new project
« Reply #16 on: August 29, 2010, 09:26:05 pm »
i think its perfect :) maybe even make it thicker!
CoriDavis
  • SammyJ Studios
    • SammyJStudios.net
Re: My new project
« Reply #17 on: August 29, 2010, 09:32:57 pm »
maybe. I definitely made the body a bit fat from the front view so i'll have to fix that.  By the way, when I mirror the image, it looks like my horse has a seam down the middle, one half is darker than the other. is that fixable?
ADSohr
Re: My new project
« Reply #18 on: August 29, 2010, 09:55:14 pm »
After you mirror you will have two separate objects, you will have to manually merge them together. Select both halves and go to Build>Join solids. That will make the two separate meshes into one single mesh that you can operate on. Next you will have to select all of the points that lie at or near 0 on the x dimension. Then go to Edit>Merge points, That will take the two separate points and merge them together into one point. If there apears to be seams left over then check to make sure that the points there merged. After that you will have to change the smoo th angle on those edges by double clicking them and increasing the smooth angle until that edge is smooth shaded.
« Last Edit: August 30, 2010, 08:13:21 am by ADSohr »
CoriDavis
  • SammyJ Studios
    • SammyJStudios.net
Re: My new project
« Reply #19 on: August 29, 2010, 11:08:14 pm »
Ok, when I finish the body I'll see how that works.  when I go to make the hair, i'll probably do a transmap mane, not sure how the tail will work though
blazecon0
Re: My new project
« Reply #20 on: August 30, 2010, 10:24:51 am »
for teh tail just do like they did in oot, made it a transparent cylender with a texture on it ^-^
CoriDavis
  • SammyJ Studios
    • SammyJStudios.net
Re: My new project
« Reply #21 on: August 30, 2010, 12:26:10 pm »
oh ok. that'll work.  when I can, i'll post my latest progress, I finished the neck and the shoulders and i'm about to start the front leg and the belly.  before I add the hair, this whole body is just going to be a horse cut in half and then it'll be mirrored.
CoriDavis
  • SammyJ Studios
    • SammyJStudios.net
Re: My new project
« Reply #22 on: August 31, 2010, 01:41:26 pm »
Well, I was going to post my progress after I finished the hoof, but when the hoof was done, it showed me that the whole body wasn't aligned correctly to the bones!  Now I have a ton of re-shaping to do, then i'll post.
Edit-
here it is fixed, it looks a bit fat, but that's easily fixable
More progress, starting the hips and made the tail bones longer
« Last Edit: August 31, 2010, 05:36:15 pm by CoriDavis »
CoriDavis
  • SammyJ Studios
    • SammyJStudios.net
Re: My new project
« Reply #23 on: August 31, 2010, 05:57:22 pm »
NOOO! Anim8or stopped responding and closed itself and I never saved!!!  I just lost everything but half the front leg!
blazecon0
Re: My new project
« Reply #24 on: August 31, 2010, 06:12:00 pm »
save save save! you can never save 2 much!
if it ever starts actin funny, save it, close it, reload it!
hope you can make it back just as well or better;)
Re: My new project
« Reply #25 on: August 31, 2010, 06:25:58 pm »
you should have autosave enabled then you should not lose your work if it crashes,(0.97 series).
 Make a folder on your computer called Autosaves then use File/Configure now point to the autosave folder, check autosave and set  interval at 5 minutes or less
See screenshot for more info.
If you do get a crash you can look in the Autosaves folder for the backup.
CoriDavis
  • SammyJ Studios
    • SammyJStudios.net
Re: My new project
« Reply #26 on: August 31, 2010, 06:47:04 pm »
omg! thank you so much! i'll do that
CoriDavis
  • SammyJ Studios
    • SammyJStudios.net
Re: My new project
« Reply #27 on: August 31, 2010, 06:52:26 pm »
wait.. is that feature only in the new version? I can't find it on mine, crap...
3Dgeek11
  • Roll Tide.
    • My DeviantART
Re: My new project
« Reply #28 on: September 01, 2010, 01:15:15 am »
0.97 anything has that feature, iirc.
Too bad, though. Good luck.. ^^
CoriDavis
  • SammyJ Studios
    • SammyJStudios.net
Re: My new project
« Reply #29 on: September 01, 2010, 08:36:51 pm »
Waah... I don't wanna start over, but I gots to....
