Author Topic: need help with Keys  (Read 9059 times)
CoriDavis
  • SammyJ Studios
    • SammyJStudios.net
need help with Keys
« on: August 16, 2010, 06:23:43 pm »
I've been working on the sequences for my animation, but the animation for the running cycle was made too slow. Too much space between Key Frames pretty much. Is there any way I can move Key Frames around without having to redo my whole sequence? like, moving a Key Frame dot back a couple spaces?
Gyperboloid
Re: need help with Keys
« Reply #1 on: August 16, 2010, 07:01:06 pm »
I have not worked on animations and don't now if there's something like key frame mooving button , but you can copy the key frame and paste it wherever you like and just delete the old one.:P
CoriDavis
  • SammyJ Studios
    • SammyJStudios.net
« Reply #2 on: August 16, 2010, 07:51:07 pm »
oh really? I did not know that! once I figure it out, that will be very helpful!
« Reply #3 on: August 16, 2010, 09:22:25 pm »
Select the single frame (should be selected in white) and you can press ctrl+c to copy or ctrl+x to cut and ctrl+v to past where you want.  You can do this with blocks of frames as well.  Also, know that in scene mode, the actual speed may lag.  You need to render to see the real speed of the animation (also, the fps or frames per second matters for how fast the animation moves, and it can be changed to what you want.)
« Reply #4 on: August 17, 2010, 03:52:49 am »
you can also delete and/or add frames.
 In scene and sequence these options are 'edit -> frames ...
 To select more than 1 frame, click the 1st frame of your selection , hold down 'shift' and click the last frame of your selection.
CoriDavis
  • SammyJ Studios
    • SammyJStudios.net
« Reply #5 on: August 17, 2010, 03:41:54 pm »
ok, I tried selecting the frame, but it won't turn white to let me copy. is there a button I have to select it with? I clicked once, I tried double-clicking, right-clicking, even with the key button on. how do i get it to select it?
« Reply #6 on: August 18, 2010, 03:25:30 am »
 To select 1 key, select the corresponding name down the left side of the timetrack.
  We are your friends, but so is the manual. :)
 Its worth a look in there. ;)
CoriDavis
  • SammyJ Studios
    • SammyJStudios.net
« Reply #7 on: August 18, 2010, 10:39:29 am »
ok, I got it to select, and copied and everything! and I looked through the manual, but now for some reason it stopped copying after a few times, I don't know what happened there
