Author Topic: Toon link graphics  (Read 24684 times)
davygravy123
  • Long time no see
Toon link graphics
« on: July 02, 2010, 08:47:20 pm »
ehlo, i wana make graphics where its toony (like where the characters have an outline),but i'm not sure how to do it. I even looked at the tutorial on it in the tut section, it didnt help me at all. please help, thanks :-\
Re: Toon link graphics
« Reply #1 on: July 03, 2010, 07:08:52 am »
The tutorial should explain everything: http://anim8or.com/tutorials/from_users/toon_notes/toon_rendering_hints.jpg
Simply make two materials: one with the toon shader --> ambient 0.1, diffuse 0.5..etc
and one with the shader for the outline --> the two sided material.
Now take you object you want to be toony. Copy it and make the copy a little bit bigger, by selecting all the faces and extruding them.
Give the original object the toon shader and the copy the outline shader. Now make sure the original model is inside the copy and you can start rendering. I believe you can only use this method using the scanline renderer, it will not work perfectly with ART.
davygravy123
  • Long time no see
« Reply #2 on: July 03, 2010, 09:04:14 am »
I tried everything, and once i got to the part where you apply the toon outline to the copy model, the object still stays the same color! help pls
« Reply #3 on: July 03, 2010, 09:39:15 am »
Did you try to render an image?  Some material settings and textures won't show up in the modeling screen, only when rendering an actual image.
davygravy123
  • Long time no see
« Reply #4 on: July 03, 2010, 10:35:42 am »
it either turns out all the way black or normal color when i render it
davygravy123
  • Long time no see
« Reply #5 on: July 03, 2010, 10:43:20 am »
can u just send me an  anim8or file w/ the toony graphics? so i can see how u did it
« Reply #6 on: July 03, 2010, 10:54:45 am »
Hi davygravy,
i attach a file for you!
note: render in SCALINE mode ok
here a old tutor mine:
http://www.anim8or.com/smf/index.php?topic=1054.msg7607#msg7607
« Last Edit: July 03, 2010, 10:57:18 am by neirao »
davygravy123
  • Long time no see
« Reply #7 on: July 03, 2010, 11:00:04 am »
WOW, THANKS!
davygravy123
  • Long time no see
« Reply #8 on: July 03, 2010, 11:01:25 am »
one thing, do you need all those colors?
davygravy123
  • Long time no see
« Reply #9 on: July 03, 2010, 11:15:34 am »
and i dont quite get the "Extrude Faces Connected" part on it, like how do u use it or do anything w/ it? ???
« Reply #10 on: July 03, 2010, 12:59:15 pm »
i think what i did for that was just scale the whole model out. instead of extruding the faces.
what extruding the faces does is makes the model (outlined one) bigger than the original model so u can see it. if you really messed with it you could make it look perfect, but it would take alot of tweaking. usually the mouth and nose area doesnt look on par. you should upload a render so we have a better perseption of what your doing and we can help out a bit more.
edit: i was wrong i did extrude faces. but the outcome is the same. it just makes it bigger. this literally took a minute or less. but this is what i came up with.
edit again: if you actually take time on doing this method it can turn out great. but in art there is really no "easy button". the tools might get easier to work with but u still have to have some skill.
« Last Edit: July 03, 2010, 01:07:30 pm by rellik420 »
« Reply #11 on: July 03, 2010, 09:01:21 pm »
no, you dont need all those colors :)
is only for show a variation of colors..you can delete other, ok
Water Music
« Reply #12 on: July 04, 2010, 02:03:15 pm »
Two-sided materials are a bit buggy with ART, so I'm not surprised you're not seeing an outline.
There is, however, a quick workaround - I'll just go over the whole process start to finish here.  Select your object; copy; paste; select one copy of the object and hide it; select all the faces of the other copy; unhide the first copy; go back to point edit mode and "extrude connected" in wirefraeme mode until you have the edge thickness you want.  Now the workaround: select the outline object, cut and paste it into a new object layer, apply a two-sided material to it (transparent front, another colour - not necessarily black to the other side), cut and paste it back to your first object.  I find that works, but it does tend to be a bit random; especially if you do weird things like put transparency and bump maps on your outline texture.
I don't check this forum everyday, but feel free to ask any follow-up questions and I'll try to help :).
3Dgeek11
  • Roll Tide.
    • My DeviantART
« Reply #13 on: July 06, 2010, 08:13:24 pm »
« Reply #14 on: July 06, 2010, 09:29:48 pm »
thanks 3DGEEK11!!  :)
