Author Topic: Two things for this forum...  (Read 7160 times)
« on: June 15, 2010, 05:37:48 pm »
Now, I know this forum has no random or forum support areas, so I'll talk here.
1) Why is it that your signature can only have 1 character?
2) How do I remove an entire sequence (in scene mode), keep the figure, and then add a new sequence?
Thanks.
Re: Two things for this forum...
« Reply #1 on: June 15, 2010, 06:05:53 pm »
Addressing your first question, signatures were being used constantly by spammers, and Steve didn't have time to stick around the forums and ban them all, so this was one easy way to root them out.
« Reply #2 on: June 15, 2010, 07:48:40 pm »
oh, ok. I see.
« Reply #3 on: June 16, 2010, 07:17:05 am »
Removing sequences can only be done by first converting the sequence to keyframes, then deleting those keyframes.
« Reply #4 on: June 16, 2010, 06:05:07 pm »
How would I do that?
« Reply #5 on: June 16, 2010, 08:56:25 pm »
In scene mode, copy 1 key from the sequence, and paste back into the same sequence.
 Anim8or will ask you to confirm that you want to change to ordinary keys, clk ok.
 Then select the first frame of what was that sequence, hold down shift, and select last frame of what was the sequence. That should sellect all those frames. Hit delete and the keys are gone.
