Author Topic: Bringing Models together?  (Read 8416 times)
yi239
« on: May 21, 2010, 08:00:45 pm »
I have a hand, not from the tutorial, but made from seperate parts.
How do i Make the fingers and thumb combine to the hand Combine to the palm to make it look like part of one big model?
Re: Bringing Models together?
« Reply #1 on: May 21, 2010, 08:16:03 pm »
this is a bit tricky. i think its mostly used when u mirror one side of the body to make it complete. grab your seperate parts and go to BUild>join solids. that will make it into one solid part. step 2 is to select the points where they connect the press L (make sure its capital L) (its called merge points i 4get how to get to it on the bar.) and there u have it. it should be a solid model.
if you dont merge the points u will get a crease where the 2 objects come together.
yi239
« Reply #2 on: May 21, 2010, 10:32:31 pm »
Thank you so much. The thumb looks much better, but the fingers look a lil more weird. Wait, i fixed it. Do the same rules apply when the models are subdivided?
And how would i solve the discoloration?
« Last Edit: May 21, 2010, 10:44:10 pm by yi239 »
« Reply #3 on: May 21, 2010, 11:19:54 pm »
not sure about that. i usually work with an unsibdivide model then subdivide it to see how it looks. so when i merge points and all that its not subdivided. i have no idea about the discoloration.
BOB_I_Ts
    • Anim8rOrg
« Reply #4 on: May 26, 2010, 06:50:58 pm »
i just upload video showing quick way of re-attaching model parts
youtube.com/watch?v=K1gIH8KQ1ow[/youtube]]youtube video: anim8or Bridge command
finally youtube processed video now has annotations
« Last Edit: May 26, 2010, 07:11:24 pm by BOB_I_Ts »
