Author Topic: Morphs on a figure  (Read 9487 times)
Morphs on a figure
« on: March 24, 2010, 12:15:50 am »
May be a dumb question but can you have a morph on a figure, that has a sequence???
siragin
    • Shatalu Productions
Re: Morphs on a figure
« Reply #1 on: March 24, 2010, 12:26:41 am »
yes you can. you create your morphs in object mode and your use them in scene mode. They won't appear in sequence mode.
« Reply #2 on: March 24, 2010, 12:44:29 am »
Well Can you tell me how to use them on the figure?
« Reply #3 on: March 24, 2010, 02:54:47 am »
asked many, many times just do a search "morphs and figures" then you will get this and many more
http://www.anim8or.com/smf/index.php?topic=930.0
« Reply #4 on: March 24, 2010, 10:43:15 am »
Ah, sorry I had dumb moment (search why didnt I bother to use search!?!?!?!?), So it is just a small bug that makes it so you can see it in the scene at first, untill you do certain things to make it show it (I hope that made sense). Anyways Thanks  ;D
« Reply #5 on: March 26, 2010, 08:22:25 am »
Hi there cooldude234,
  you add morph targets to your objects, then add the objects to your figure.
 In scene mode, it is the actual objects, attached to your figures bones, which have the morphs.
The "certain things to make it show" are 'animating your morph targets'.
 These vids might help:
 Adding morph targets to object
 Animating morph targets. (making them show in scene mode)
&feature=related
 The only thing missing there is adding the objects to your figure.  (although the end of the 2nd vid  does show briefly and simply, without 'skinning'. )
   Having a sequence added to the same figure is fine.  Morphs will still work. ;)
 Hope that helps.  :)
« Last Edit: March 26, 2010, 08:30:12 am by johnar »
Josmic8or
  • anim8t & celebr8t
    • JOSIAHSTUDIOS
« Reply #6 on: March 27, 2010, 07:45:51 am »
But sometimes when you add morph targets to your objects, then add the objects to your figure the morphs sometimes dont appear in scene mode.
When that happens I just switch to object mode then go back to scene mode and walla!The morphs are there.
« Reply #7 on: March 27, 2010, 06:00:28 pm »
Josmic8or - Thats what I was reffering to when I said "certain things to make it show"
My issue was, I just couldnt see them, so the doing the"certain things to make it show", well made it show and fixed issue
