Author Topic: Projections  (Read 15746 times)
Projections
« on: March 22, 2010, 12:21:05 am »
I know there is an actuall term for this (just cant remember at this moment), anyways, is there any way of using ART to projects a image on to a surface? If so tell me, thanks  ;D
BOB_I_Ts
    • Anim8rOrg
Re: Projections
« Reply #1 on: March 22, 2010, 11:22:53 am »
In the material editor click texture button then you can load cube maps or a single texture into to the "Env. map" channel.
You can also add reflections with attribute editor all the attributes are listed in the anim8or manual.
Re: Projections
« Reply #2 on: March 22, 2010, 12:18:28 pm »
Or are you talking about Textures? In that case use the Diffuse slot to add your image.
Re: Projections
« Reply #3 on: March 22, 2010, 03:03:05 pm »
Well I was talking about a light that projects a texture on to surfaces of objects in a scene. An example, well an Projector, what else?
Re: Projections
« Reply #4 on: March 22, 2010, 06:53:54 pm »
Thanks for stating the actuall term. That kind of sucks that anim8or doesnt, and I cant afford 3dsmax or maya, so I guess I will have to work around it for now.
Re: Projections
« Reply #5 on: March 22, 2010, 11:45:55 pm »
You can easily fake it, especially if it's a still image.  Just incorporate it into your texture!  You can use light effects to make it looks like a projector light as well, it's really pretty simple.
Re: Projections
« Reply #6 on: March 23, 2010, 02:09:17 am »
i think it would be easily faked. i remember some1 mentioning billboards a while back. and im pretty sure that was just animated textures. but i think you can do that with morphs. and if u cant just make seperate objects. but if u have the frame rate linked up u should b able to do it easy.
Re: Projections
« Reply #7 on: March 23, 2010, 10:26:38 am »
hmm, didnt think about using morphs, might take alot of work but very much possible.
Re: Projections
« Reply #8 on: March 23, 2010, 04:52:49 pm »
sample gel attached to spotlight in carrara.
Re: Projections
« Reply #9 on: March 23, 2010, 11:37:08 pm »
LOL
Yep, carrara is yet again too expensive, that and I cant buy online, unless if it is from ebay (I get my brother to use his account then)
Re: Projections
« Reply #10 on: March 24, 2010, 03:15:07 pm »
cooldude, if you haven't noticed by their advertisements in the past, Animanon.com has a free version of carrara you can download.  They do require you to register and post one comment I believe, but after that it's a free download that Carrara provided some time ago for a short time.
If you really need a projection, it sounds like Carrara would most likely work.
Jdez
    • Tech Blog
Re: Projections
« Reply #11 on: March 24, 2010, 04:38:36 pm »
Also I believe Blender can do gels, and its free like anim8or.
Having fun with ASL!
