Author Topic: Cannot get a Plugin to work  (Read 7221 times)
Notunknown
« on: January 30, 2010, 12:48:34 pm »
How can I use a plugin?
how can I use it and/or is there a plugin to export in .x files?
« Last Edit: January 30, 2010, 12:50:42 pm by Notunknown »
Re: Cannot get a Plugin to work
« Reply #1 on: January 30, 2010, 01:14:14 pm »
Quote from: Notunknown
See http://www.anim8or.com/scripts/index.html, the "Installing Plug-ins" section
Once an export plugin is installed, you'll need to restart Anim8or and then you can just click Object > Export.
Check the ASL Scripts Database, you'll find an .x exporter there.
Notunknown
« Reply #2 on: January 30, 2010, 01:16:08 pm »
should the configure screen reset when I restart Anim8or?
« Reply #3 on: January 30, 2010, 01:24:12 pm »
No, it shouldn't.
The settings in the Configure dialog box should be saved after you click OK and should not change after restarting Anim8or.
