Author Topic: Feature Suggestion: Front and Back options  (Read 6691 times)
The7DeadlyVenomz
« on: January 24, 2010, 11:57:54 pm »
I'd like to see a front and back option for painting weights, like the front and back option in object editor mode. A problem I run into is that when painting weights, you end up painting more than you want to. If you paint the front of the model, you paint the back too.
I'd also like to see the edit->hide option apply to points, faces, and lines, not just objects. On complicated models, it would be very useful to be able to hide some parts of the model to edit more precisely.
Re: Feature Suggestion: Front and Back options
« Reply #1 on: January 25, 2010, 05:22:21 am »
That can easily be done by putting a single color reference image at a spot in your model so that you only see that part of the mesh that you want to edit and disable editing of the 'back'
