Author Topic: is there a better way to do this  (Read 9089 times)
mak
« on: January 18, 2010, 02:27:01 pm »
first off i renderd this in open gl for time
im trying to create debree and ruble infront of this bolder as it hits the ground. i used fire from teran8or(sp?) and substituted a rock for the fire texture.( which my computer realy dosnt like) it looks like crap.
should i try differnt fire settings or mabee a difernt prog. or ..... your sugestions
please
realisim is for reality
mak
Re: is there a better way to do this
« Reply #1 on: January 18, 2010, 02:29:08 pm »
and why dose terranim8or wipe out all my keys for the figures?
« Reply #2 on: January 19, 2010, 05:06:17 am »
well for your debree a program with a particle system might be your answer. ive pondered getting a particle effect in anim8or. it might be tricky but you can use a series of transmaps. it will probably get tedious adding and deleting objects for each keyframe but if you make it right i think it will come out looking good. making the transmaps i dont think will be that hard. all you need is a program like photoshop or gimp(free) which has layers. that way you can hide the layers as needed untill you get ur full animation. then save each layer as a jpeg. with a little work i think you can get what u need. hope this helps.
« Reply #3 on: January 19, 2010, 07:13:12 am »
I used a series of transmaps for the debris clouds in this animation:  http://www.rudyschneider.com/More_Projects/Triform.wmv
mak
« Reply #4 on: January 19, 2010, 10:49:27 am »
never played with transmaps before. guess its time, thanks.
cool vid rudy
« Reply #5 on: January 19, 2010, 05:54:38 pm »
nice work rudy
