Author Topic: Help in exporting in 3DS  (Read 6680 times)
nalds
« on: March 02, 2008, 05:45:12 am »
Hi!
If anyone could help me correctly on how to export a model made with anim8or with textures in 3DS format?  ???
I've been tinkering some settings that might get it to work but when I tried loading the exported file on some 3DS viewers,
it only loads up the mesh. Tried also opening the 3ds file in a text editor to see if the resource texture is
included and yes, no problems at all.
What I've done successfully is importing a 3ds file that I downloaded on the web and exporting it in 3ds again, then loading it to the viewer. this works.
Appreciate any help. Thanks  :)
nalds
Re: Help in exporting in 3DS
« Reply #1 on: March 02, 2008, 06:02:41 am »
Ok, I've solved my own problem. Im trying to use a GIF texture, so I convert it to jpg and it now worked fine.
« Reply #2 on: March 02, 2008, 06:37:42 am »
nalds : also make sure all your textures are in the same directory as the mesh model, causes problems if they are not in the same place as the mesh.
