Author Topic: Texture  (Read 8090 times)
B++
Texture
« on: December 13, 2009, 02:12:12 pm »
I hv applied a texture on a box. the texture is wood texture. problem is, i m not seeing the texture on the box rather seeing brown color. According to manual it should show the texture on the mesh as soon as it is applied. There are no dicription about texture mapping on the manual. kindly help.
Regards
Your signature here;
TheRetroZombie
  • I do crap animations.
    • Youtube Channel
Re: Texture
« Reply #1 on: December 13, 2009, 02:16:55 pm »
Use the UV tool. The box has to be a mesh first. Then click on a toll and a box will appear around it. when you move it around you will see the texture. Though you'll have to fix it cause some sides it will be all stretched out.
X
B++
Re: Texture
« Reply #2 on: December 13, 2009, 03:07:29 pm »
I hv edited it to make a crate, just some extruson. I am not getting the UV mapping dialog box. Where is it?
Re: Texture
« Reply #3 on: December 13, 2009, 05:30:33 pm »
 Thought i saw this same question just recently.
 After you have added your texture:
 Select your object and hit the 'UV' button, which is on your left in the side toolbar. (UV)
  A popup dialog should appear and say 'Enable texture generation for: Mesh01. (or whtever mesh it is).
 Click 'yes' and a yellow box will appear around your object, with a yellow grid.
  Use left mouse button to rotate texture, right mb to slide texture, and middle mb to scale.
 Anim8or version 0.97d
Re: Texture
« Reply #4 on: December 13, 2009, 08:25:03 pm »
sometimes i have to move the uv arc. just move it a little and it will pop up on your cube.
B++
Re: Texture
« Reply #5 on: December 13, 2009, 10:07:32 pm »
Thanks a lot for the reply and help
Regards
