Author Topic: Hi. I need some help  (Read 10962 times)
sloGGan
« on: November 18, 2009, 06:15:15 am »
Hi, how to make light like this photo
I need one tutorial for this because I try to understand from other peoples, but I can not understand! I need one tutorial PLEASE!
Re: Hi. I need some help
« Reply #1 on: November 18, 2009, 06:20:43 am »
That image was very probably rendered in carrera, knowing kreator.. but if you want to make it in anim8or, you will have to make spotlights.
When you make a new light, in the properties you can choose what kind of light it will be; Infinite, Local or Spot.
Click on the Spot radio button. You now have a spotlight, you can change the properties of the spotlight by clicking on the Advanced button.
If you position the spotlights right, you can create something like the image.
The smoke you might have to make in post-production.
Good luck
sloGGan
« Reply #2 on: November 18, 2009, 05:59:14 pm »
"If you position the spotlights right, you can create something like the image" what to do, i position light but don't show light like photo
Pincho
« Reply #3 on: November 18, 2009, 07:47:15 pm »
You will need something like flat spheres for the lights. Maybe transparent, white with lights inside. The smoke effect can be done with cylinders expanded on 1 end, with a smoke texture, and transparent 0.1.
« Reply #4 on: November 19, 2009, 11:37:35 am »
You might want to take a look at the lighting tutorial for anim8or for lighting effects.
« Reply #5 on: November 19, 2009, 11:58:27 am »
No this picture is not mine $imon  its Arik`s and EriucAug`s ( i don`t want to be accused of plagiarism, enough rocks have been thrown my way! )
I would though, imagine its done in Carrara with a couple of spots and built in Lightcones.
Carrara does have the advantage of lots of extras that cannot be done in Anim8or and is an welcomeextra tool in the world of 3D!
« Last Edit: November 19, 2009, 02:34:47 pm by kreator »
Indian8or
« Reply #6 on: November 20, 2009, 09:27:23 am »
Follow all the above instructions in anim8or and then wait for 110 years for the render to complete.  You will get the desired result. ;D
« Reply #7 on: November 20, 2009, 10:28:43 am »
HaHa!!... I can imagine that ... Carrara render would be almost instanteous, perhaps just under a minute in full raytrace
I`ll post a rundown of what Carrara can do and what you are all missing! but I still use anim8or for the modelling as its far easier than Carrara`s modelling room which is awful.
I provided Aric & EricAug with Carrara FOC  you too,can get it at animanon.com if you just follow some simple rules....participate
just some of its assets Caustics,AO, animated Textures, Displacement mapping, gels, lightcones, aura, fast rendering, multi threading, render node(render farm) import 3ds,obj etc (not anim8or) use bvh data the pros for it on and on.
 The program really is just another tool , that you should have in your essentials!
take a look here  http://www.animanon.com/Forum/index.php?topic=1257.0 a couple of issues of the Carrara Magazine
our own headwax is featured in one of them
« Last Edit: November 20, 2009, 11:02:11 am by kreator »
