Author Topic: Mirror and shadows.  (Read 11036 times)
sloGGan
Mirror and shadows.
« on: November 07, 2009, 04:35:23 pm »
How to make mirror (not mirror object) but mirror like this .
Or shadows make like this , not this :(
Jdez
    • Tech Blog
Re: Mirror and shadows.
« Reply #1 on: November 07, 2009, 06:26:12 pm »
For the mirror... look it up where you found the picture. and you need to have v.97 preview. The shadows. You must enable shadows cast and recieved on the object and the plane. Then you need to change the shadow settings of the light. If you don't understand this I can explain in more detail
Having fun with ASL!
sloGGan
« Reply #2 on: November 08, 2009, 11:55:08 am »
I can not understand in anim8or.com, tutorial. I need some help. Jdez, not thanks for your help :S.
Shadows no like 2nd picture, but as 1st. And mirror like this http://wpcontent.answers.com/wikipedia/commons/5/52/Mirror.jpg
odp04y
« Reply #3 on: November 08, 2009, 12:54:51 pm »
The mirror in Anim8or is just a material.
Make sure you have v.97 then in the material editor
click attributes and enter new
in the top box type "specular" (without quotes)
in the bottom box type "reflection" (without quotes)
You can then edit the specular value in the material editor to adjust the amount of reflection.
For soft shadows in scene mode create a light double click it
click advanced
check the 'cast shadows' box
select raytrace and check the 'soft' box
then change the size box to about 3 (the larger this value the softer the shadows)
sloGGan
« Reply #4 on: November 09, 2009, 04:48:24 pm »
Thanks, but i can not find "reflection" in bottom box.
« Reply #5 on: November 09, 2009, 05:23:30 pm »
You will have to type it yourself ;) but first select the typ: string
