Author Topic: can't change colors  (Read 8829 times)
chrisusvi
can't change colors
« on: November 06, 2009, 12:12:04 pm »
can't find where to change colors and to bring objects forwards and backwards.
I've been looking for 'material editor' surface properties dialog box and can't find it.
Thanks.
chrisusvi
odp04y
Re: can't change colors
« Reply #1 on: November 06, 2009, 12:33:17 pm »
When in anim8or press Enter and the material toolbar will appear next to the toolbar on the left. To edit the material double-click the "new" square and you'll find the material editor.
To move objects along the z axis click the move button and use the right mouse button the move a selected object.
Pincho
« Reply #2 on: November 07, 2009, 08:52:14 am »
Ah is that what you do to move Z. I always use the top view.
odp04y
« Reply #3 on: November 07, 2009, 10:29:24 am »
I use the top view as well as it's hard to tell how far your object has moved using that method unless you are in the perspective view.
« Reply #4 on: November 08, 2009, 04:07:20 am »
the colors part i dont know what you mean. are u on the default grey color? and you cant cvhange to red or blue?
but i think i can help on your movement.
in object mode it has set coordenates. i think your best bet is to be on x=0 y=0 z=0. you really cant go wrong with that,
if you mean to zoom in or out use your arc rotate. "read the manual"
i dont see the need to mode yoiur object in object mode but if you need to move in scene mode... go to your "viewprt right" or hit the 6 on your NumPad. selected x only and push it forward or backwards. *that would control your z axis because yout faceing right and right would be forward and backward. or you can go to ur top view and hit the y axis only and go up and down. same thing only different. like those guys said.
i think what u really need to do is figure out that your in a 3d world and you need to figure out what axis r what
(in front view)
x = left and right
y = up and down
z = back and forth (depth)
i hope we helped, cause i dunno what else 2 tell u.
