Author Topic: Make Scripts  (Read 11141 times)
Programmer
Make Scripts
« on: October 14, 2009, 06:49:21 pm »
Umm... so how do I make ASL scripts, and what does 'ASL' mean? ::)
Re: Make Scripts
« Reply #1 on: October 14, 2009, 08:44:31 pm »
ASL = Anim8or Script Language.
Read the ASL documentaion  see the scripts tab in the frame on your left or use this link
http://www.anim8or.com/scripts/spec/Anim8or_Scripting_Language.html
Jdez
    • Tech Blog
Re: Make Scripts
« Reply #2 on: October 23, 2009, 06:51:48 pm »
If you are intrested in making primitve shape scripts check out the plane script. Also there are a couple tutorials on material scripts and some other things. I'll try to find the links.
Having fun with ASL!
Jdez
    • Tech Blog
Re: Make Scripts
« Reply #3 on: October 31, 2009, 08:40:46 am »
Ok I have found a couple of Tutorials...
If you are interested in controller scripting follow this link that Kubjazz provided me with when I asked the same question: http://www.biederman.net/leslie/tutorials/ASL%20Scripting/ASL_scripting.htm
Also on this page there is a downloadable PDF tutorial on material scripting: http://www.anim8or.com/smf/index.php?topic=1759.0 just scroll down a little bit. I am working on a bit of a more advanced version of the latter but I will need to dig around a little first. I had gave it to DotAn8 but it looks like there won't be a new one of those for a while...
edit: By the way for the second link only download the pdf, the second link on the page...
Jdez
    • Tech Blog
Re: Make Scripts
« Reply #4 on: December 22, 2009, 06:50:51 am »
You should just look at the ASL Scripts databas (It's a sticky) then choose the ones you think are the most useful.. Once you have made a list pm the authors and ask them, if they don't respond pm kubjazz he should be able to get ahold of them or give you permission.
