Author Topic: Bones will Not move in sequence mode  (Read 6664 times)
ronkleim
« on: October 05, 2009, 04:27:32 am »
Point and click drag doesn't work.
It's also a little weird that at first your objects
disappear when switching modes.
Is this a Vista problem?  :'(
Re: Bones will Not move in sequence mode
« Reply #1 on: October 05, 2009, 04:49:22 am »
Rotating bones in the sequence mode is probably the most frequently asked questions...
I spent about 30 seconds searching the forum and this is what I found:
http://www.anim8or.com/smf/index.php?topic=2084.0 (see the FAQ section)
http://www.anim8or.com/smf/index.php?topic=1907.0
http://www.anim8or.com/smf/index.php?topic=2649.0
Well... Does that solve your problem?
As for the disappearing objects, I'm not sure what you mean...
ronkleim
« Reply #2 on: October 05, 2009, 05:06:53 am »
Thanks now it works :)
So it's kind of a bug then that you can't move the bones in FRONT view, that's kinda weird.
I mean when you create an object then you switch modes , the object disappears.
I guess you have name a project first then it won't do that.
