Author Topic: Texturing Scripts  (Read 10368 times)
Jdez
    • Tech Blog
Texturing Scripts
« on: September 19, 2009, 04:36:18 am »
I was wondering if anyone has written any material scripts that also use textures?
Having fun with ASL!
Re: Texturing Scripts
« Reply #1 on: September 20, 2009, 04:50:12 am »
Hello Jdez,
I'm not sure if there are any material scripts that use textures... Anyway, I wrote a very simple one for you:
Code: [Select]
#command("object");
material $m;
texture $t;
/* Create a new material */
$m = project.NewMaterial("MyMaterial");
/* Create a new texture */
$t = project.NewTexture("MyTexture");
$t.SetFileName("c:\\Anim8or\\Example.jpg"); /* Enter your file path here */
/* Attach the texture to the newly created material */
$m.SetTexture(TEXTURE_DIFFUSE, $t);
/* Adjust the material settings */
$m.alpha = 0.5;
$m.diffuse = (0, 1, 0.5);
$m.Kd = 1;
$m.Ks = 0;
$m.SetBlendMode(TEXTURE_DIFFUSE, BLEND_MODE_LIGHTEN);
.... (more material settings)
The file path can be absolute or relative. If it is relative, then it starts from the "Project" folder that can be configured in the "File>Configure" dialog box.
I hope it helped ;)
Jdez
    • Tech Blog
« Reply #2 on: September 23, 2009, 07:16:05 am »
Thanks very much!
BOB_I_Ts
    • Anim8rOrg
« Reply #3 on: October 21, 2009, 09:49:48 am »
i made one using cube maps for a toon ink output
material_ink.zip extract all into your script folder then use script>run script
